How do I set the IDE for Python in ArcGIS Pro to let me edit the scripts of GUI tools?
3010
6
09-14-2020 04:30 PM
muqdadAl_hamami
Hi all,
I have a problem setting the IDE by ArcGIS pro when I right-click a script and select Edit. I have tried to enter the file path (i.e. files like IDLE)  under the geoprocessing option but still non-active when right-clicking on any tool, Edit is still hidden, not active. Any help please to activate the editing option?
DanPatterson
MVP Esteemed Contributor
The toolbox structure has changed in 2.6.*
You can't edit them via the right-click method.
Read on if you are fully versed in working with python....
The toolbox is located in the folder  ( note.... arc_pro ... is my arcgis pro installation folder so change accordingly)
C:\arc_pro\Resources\ArcToolBox\Toolboxes\Spatial Statistics Tools.tbx\BuildBalancedZones.tool
The script is....
C:\arc_pro\Resources\ArcToolBox\Toolboxes\Spatial Statistics Tools.tbx\Spatial Statistics Tools.pyt
and associated files
C:\arc_pro\Resources\ArcToolBox\Toolboxes\Spatial Statistics Tools.tbx\toolbox.content
etc
and Build Balanced Zones is therein
Spatial statistics associated scripts are located in the folder
C:\arc_pro\Resources\ArcToolBox\Scripts
Finally the script.... Spatial Statistics Tools.pyt script contains the class
class BuildBalancedZones(object)
on line 11,118
Don't mess with the installed scripts unless you know exactly what you are doing
... sort of retired...
muqdadAl_hamami
Thanks, sir for your kind reply, could you please let me know how can I do it by ArcMap 10.8 instead of using ArcPro because it is more complicated than before.  Thanks again
DanPatterson
Sorry... I haven't used ArcMap is years
muqdadAl_hamami
Actually, I tried to use your instructions that published in the old thread (in 2018) and apply that steps on the old AcrPro 2.3 version but it also does not works.  However, I went yesterday to the Spatial statistics associated scripts that are located in the folder
I found the scripts of tools but the names of these scripts are not matched with the names on the toolbox list, so is there any way to match between the scripts on that folder and the names of tools on the list of ToolBox?
Thanks again, sir.
DanPatterson
As I somewhat indicated earlier,  BuildBalancedZones isn't a separate "script" but is a called class in the *.pyt script listed below
on line 11,118
DanPatterson
Addendum.
What I describe is for Pro 2.6.1.... Pro 2.3 uses the 'old' way of describing toolboxes.
An upgrade would be prudent
