How do I rotate a feature class in ArcGIS Pro?
7511
6
11-12-2019 01:58 PM
RobDunfey
I have one point feature class and one polyline feature class in a projected coordinate reference system. How can I rotate these feature classes by a number of degrees?  For example, rotate all features in the feature class through 90 degrees so what did face north now faces east? The polylines and point feature class represent the outline of an oil rig and I would like to rotate the feature classes to match the rig orientation in the real world.
Scott_Harris
Hi Rob,
  1. Open the Rotate tool - Move, rotate, or scale a feature—ArcGIS Pro | ArcGIS Desktop
  2. Select the features you want to rotate.
  3. If needed, move the anchor by holding CTRL.
  4. Hit TAB to set a rotation angle if using dynamic constraints (Constrain direction for a segment—ArcGIS Pro | ArcGIS Desktop) or hit A key to bring up a dialog to set the angle.
  5. Finish the job with F2.
Bonus: if you want to snap while rotating hit the S key to set a secondary rotation anchor:
This shows a polygon and line, but it will work just the same with points too.
-Scott
BruceHarold
Esri Frequent Contributor
Hello Rob, if just editing the feature class isn't well-controlled enough for you there is code in this sample you could re-purpose for the job:
https://pm.maps.arcgis.com/home/item.html?id=9398bd2232cb4c8490b0b05015364d28
RobDunfey
Hi Bruce, how can I do it by editing the feature class? Ideally I would select all features and then enter a rotation angle?
BruceHarold
Hi, I had to go ask a colleague, but you select all the features you want to rotate, select the Rotate tool, move the rotation circle center point to where you need (control key, drag it and snap it somewhere, then spin it round using the green circle edge as a handle.  There is an option to enter an angle (which is relative to the map's rotation).  Looks like someone beat me to the workflow below!
Scott_Harris
Hi Rob,
-Scott
RobDunfey
Scott, Bruce - thanks for taking the time to reply.  Awesome videos and exactly what I need, Many Thanks! Rob
KoryKramer
Esri Community Moderator
Rob, please remember to mark an answer correct to help others who find this thread.
