Hiding Labels Within Extent Indicator on ArcGIS pro
2293
07-11-2024 05:43 AM
VassilisTrigkas1974
Hello,
I have a map with an extent indicator and a frame to show an area at a larger scale. Is there a way to hide the labels only for the points that are within the extent indicator?
Robert_LeClair
Esri Esteemed Contributor
One idea is to create a new attribute in the layer called Extent_Indicator.  Then calculate it 'yes' or 'no'.  From there use Definition Query on the layer to only draw those points that have a value of 'yes'.  Then label those items.
VassilisTrigkas1974
I don't want to hide the points, but only the labels of the specific points. An idea very close to yours is to hide some labels with Arcade (No/Yes).
Robert_LeClair
True - you could use the Labeling tab->Label Class group and create an expression for a label class where 'inset = 'yes' or something similar.
KearyLarson2
Just checking to see if there are any other more elegant solutions since this was discussed. I have been looking at the interface and don't see any other settings or properties that would prevent labels in the extent window from displaying.  To 'solve' this we created additional map frames and drew them on top of the main map frame in the layout and sent the extent such that the layers line up.  In the additional map frames, we do not have labels turned on so only the features are visible in the extent windows.
KoyaBrown2
I am running 3.7.0 and there is an override layer visibility tool you can used to control label sync
