Help with arcade expression
2103
08-30-2022 07:22 AM
Robswann
I am trying to pull from a feature set the location by filtering it by the relationship ID. I have similar formulas that work fine, but for some reason I am having trouble with this one. I have the following, could someone please help? The below rule is working, but pulling the first row from attribute table. Thanks
var Land = FeatureSetByName($datastore, "Land", [ "Location","Name","County","School_District","ID"]);
VAR LOCATION = FILTER(LAND,"ID=$feature.ID")
FOR(VAR I IN LAND)
RETURN I.LOCATION
JohannesLindner
You're telling your DBMS to use the literal SQL query "ID = $feature.ID". This isn't a valid where clause and so it fails.
What you want to do is store the $feature.ID in a variable and use the @ notation of Filter() to take care of the type formatting for you.
Also, you aren't looping over the filtered feature set, but over the whole table...
var Land = FeatureSetByName($datastore, "Land", [ "Location", "Name", "County", "School_District", "ID"]);
var id = $feature.ID
var related = Filter(Land,"ID=@id")
var location = First(related)
if(location == null) {
    // no related features found -> return a default value
    return null
// else return the related feature's ID
return location.ID
Have a great day!
Johannes
JillianStanford
Do you mean to loop through the original dataset or the filtered dataset? Also, I'm not sure if the curly braces are required in Arcade.
https://developers.arcgis.com/arcade/guide/logic/#for-loops
Does the following work?
FOR(VAR I IN LOCATION ) {
     RETURN I.LOCATION
JohannesLindner
    return null
return location.ID
Have a great day!
Johannes
Robswann
Very Helpful. Thank so much!
