Help understanding 'X/Y Offset' and 'pt' value
1202
04-25-2024 01:32 PM
MarkReddick
Running Pro 3.1.0 - Feature Linked Annotations
I'm confused by the values that we put in for annotation X and Y Offsets, which i understand are Pt values. I understand that 1 Point is approx 0.003527778meters, but when i put in a value of 50 for the Y Offset the annotation jumps to approx 200meters north which is much greater than what i was expecting.
Is this somehow related to the annotation reference scale? What is the correct formula I would need to consider when trying to work out an offset value if the annotation was moved via some client application.
I just need to understand what the Esri client app is doing with that 'pt' value when coming up with the distance offset that it does.
Many thanks in advance!
mark
