Grid button is missing
5240
11-16-2020 06:43 PM
by Anonymous User
Not applicable
I am trying to add a measured grid in ArcGIS Pro 1.2.0. However, this option is not shown on the ribbon as we can see in the attached picture.
DanPatterson
MVP Esteemed Contributor
In Pro 2.6 you need at least 2 map frames on the layout.  If you only have one, then a bit of hovering should show some context sensitive help.  If you are really using version 1.2, you would be advised to upgrade because a lot has changed
... sort of retired...
by Anonymous User
Not applicable
Thank you for the feedback. I do have two map frames. The grid button is not only unavailable but invisible.
Pål_Herman_Sund
Hi @Anonymous User  are You seriously writing 1.2.0 version of Pro or is that  mis-spelling? You do need to upgrade if 1.2.0 is true..
For the missing "Grid" it is hard to tell from your screenshot. In the layout you need to activate a Map Frame in the Contents Pane for the Grid command to be active. ie
Not active
Active
DanPatterson
That leaves looking for bugs on the Tech Support site
Bug BUG-000128102
If this is the one, it is by design.
If it isn't that bug, then you will need to file a case with Tech Support
