GPU ID?
3859
06-28-2022 06:46 AM
PieterFavoreel
Hello,
I'm using ArcGIS Pro and want to run the 'Train Deep Learning Model' tool. For doing this, it's absolutely necessary to specify the ID of the GPU you're using (in the 'Environments' tab - default setting is 0), and I can't find that one. My device has two GPU IDs, one of which (a NVIDIA GeForce GTX) should be able to do the job.  Task manager just labels them as "GPU 0" and "GPU 1", but this doesn't work.
What is a GPU ID supposed to look like? How can I find it?
Thanks a lot if someone could help me.
JayantaPoddar
Task Manager actually gives me a lot of info.
Since my NVIDIA graphics card is GPU1, I should set the GPU ID to 1.
GPU ID (Environment setting)—ArcGIS Pro | Documentation
Think Location
