going from 2d to 3d layer in arcpro changes polygon shape
898
05-31-2019 08:36 AM
DanielClement
So I have a polygon layer, and Im trying to use extrude feature by an attribute. All is well. Except that I notice when i move the layer from "2D Layers" to the "3D Layers" in the contents pane, and look at the polygon, it drastically modifies one specific portion of the polygon for no apparent reason. Is this a known issue? Or am I doing something wrong?
In the attached image, the black outline is the 2D polygon as it should be. The Orange layer, is the same layer, as a "3D layer". As you can see its very strange, as some areas to the south are not altered, but to the north the boundaries are sort of simplified, and altered.
Tags (1)
