Georeferencing problem in 2.9: "Fit to display" only works on 1 out of 2 tiff-files.
1084
01-18-2022 11:21 AM
Eliash
Hi!
I am learning how to georeference in ArcGIS Pro 2.9. In the reference raster layer, I zoom in. I then select the tiff file I want to georeference >> Imagery >> Georeference >> Fit to display. This works for 1 out of 2 tiff-files. They are both on the top of the drawing order, and they don't block each other out. For the tiff that won't work, I can still zoom to it and see it floating in nowhere. It won't "listen" to my command to fit to display.
DanPatterson
MVP Esteemed Contributor
What if you add just the one tiff? and not the other, same behaviour?
I am trying to figure out where you are along these steps
Georeference a raster to a referenced layer—ArcGIS Pro | Documentation
... sort of retired...
AdrianWelsh
MVP Honored Contributor
Eliash,
One thing you could do to troubleshoot this issue is, in the folder where you have your Tiff2 stored, delete the auxiliary data with it (like the . tfw, .xml, etc.). Then try loading the tiff back into your map and trying again.
