Georeference Anchor Re-Centers After Every Operation
556
12-16-2025 08:57 AM
MitchellDrennan
Is there a way to get the georeferencing anchor point (not "control point") to stay put when rotating/scaling raster images using the georeferencing tools? I can re-position the anchor point using the Ctrl key, and it stays put during the immediately following rotate/scale operation, but as soon as that operation is finished, the anchor point moves back to the center of the raster. It would be nice if the anchor point stayed where I placed it because I frequently go through a whole sequence of rotate/scale/rotate/scale/etc/etc/etc operations, and having to re-position the anchor point between each operation is a pain.
The gif below shows an example of what I'm talking about. In reality, I'm working with much larger maps, requiring me to pan and zoom much more in order to get back to the center of the map to grab the anchor point again.
Essentially, I'm interested in the practice of reducing mouse clicks and keystrokes, and not having to re-position the anchor point each time would be a step in the right direction.
Robert_LeClair
Esri Esteemed Contributor
@MitchellDrennan - I am seeing this behavior in my ArcGIS Pro 3.6 application as well.  I search through the Support Calls to see if there was other customers calling about this issue and also reviewed the Enhancement ideas as well to no avail.  I would recommend you create an ArcGIS Pro Idea about this item so it gets visibility with the ArcGIS Pro Development Team...
