Geometric Precision Discrepancies During Line Splitting in ArcGIS Pro 3.3.2
1057
05-06-2025 06:27 AM
eissa333
Summary:
When splitting a polyline feature using tools such as Clip, Divide, or conversion to COGO lines, a minor but consistent discrepancy is observed in the calculated bearing of the resulting line segments compared to the original input line. This discrepancy, while small (approximately 0.00003 degrees), is repeatable and unacceptable for high-precision mapping and engineering applications.
Detailed Description:
A polyline feature with an original bearing of 359.97142191134566 (N00°01'43"W) is being split based on parcel boundaries. Following the splitting operation, the resulting line segments exhibit bearings of approximately 359.97138135206296 (N00°01'43"W) and 359.97176028095197(N00°01'42"W). This deviation from the original bearing is not present when performing the same operation in Autodesk Civil 3D using the same source data and coordinate system.
Environment:
  • Coordinate System: NAD 1983 NSR2007 StatePlane California VI FIPS 0406 (US Feet)- Confirmed to be consistent across the project and feature class.
Reproducibility:
The issue is consistently reproducible when splitting the aforementioned polyline feature using various methods within ArcGIS Pro.
AyanPalit
@eissa333 Please post ArcGIS Pro version; are you using Parcel Fabric ? The issue seems to be data specific and recommend submitting a Esri Technical Support case.
Ayan Palit | Principal Consultant Esri
eissa333
Ayan, I am using ArcGIS Pro 3.3.2 (title), and not using Parcel fabric.
