Generate clustered random point data with set number of points
5997
02-09-2023 09:26 AM
MatthewPoppleton
I am working on a simulation to compare different models' estimates of population counts in areas with known total observations. I am using a preset amount of points (e.g. 50,000) to represent observations within my study area, and run models using line transects that overlap with those points.
I currently have a spatially balanced point feature class that acts as a uniform distribution, and another with point clustering based on land-cover type (stationary). I am trying to figure out a way to generate a third point feature class of 50,000 non-stationary randomly clustered points.
What I've tried so far is using the "Generate Random Points" tool to generate 50,000 points within my boundary, and set a low minimum allowed distance (e.g. 1 meter). Then I used the "Density-based clustering" tool to detect areas of clustered points and copied them to a new feature class. This leaves me with the clustered areas and no noise points. However with the noise subtracted I am left with far less than the desired amount of points. The output looks good but I would like to set the total number of points to be clustered. See screenshots for reference.
I could use a higher count of random points and use trial and error to end up with a clustered set around 50,000 but this wouldn't be ideal as I wouldn't have an exact count and it probably wouldn't be very replicable.
I assume this has been done before but I haven't been able to find how. Is there a way to achieve this using other geoprocessing tools or perhaps arcpy?
JohannesLindner
A naive approach:
  1. create clusters with random point counts until you reach 50k points
  2. create random center points for the clusters
  3. create buffers with random radii around the cluster centers
  4. use these buffers as constraining fc for the Random Points tool
Script:
import arcpy
import random
# tool parameters
output_folder = ""
output_name = "RandomPointClusters"
constraining_fc = "TestPolygons"
num_of_points = 50000
min_points_in_cluster = 20
max_points_in_cluster = 100
min_cluster_radius = 500
max_cluster_radius = 1500
min_point_distance = 1
# randomly distribute the points into clusters
rest = num_of_points
clusters = []
while rest > 0:
    num = random.randint(min_points_in_cluster, max_points_in_cluster)
    num = min(num, rest)
    clusters.append(num)
    rest -= num
print(f"{len(clusters)} clusters will be created.")
# randomly create the cluster centers
cluster_centers = arcpy.management.CreateRandomPoints("memory", "ClusterCenters", constraining_fc, None, len(clusters), min_point_distance)
# randomly create the cluster buffers
sr = arcpy.Describe(constraining_fc).spatialReference
cluster_buffers = arcpy.management.CreateFeatureclass("memory", "ClusterBuffers", "POLYGON", spatial_reference=sr)
arcpy.management.AddField(cluster_buffers, "NumOfPoints", "LONG")
with arcpy.da.InsertCursor(cluster_buffers, ["SHAPE@", "NumOfPoints"]) as i_cursor:
    with arcpy.da.SearchCursor(cluster_centers, ["SHAPE@", "OID@"]) as s_cursor:
        for cluster_center, cluster_id in s_cursor:
            cluster_radius = random.randint(min_cluster_radius, max_cluster_radius)
            cluster_buffer = cluster_center.buffer(cluster_radius)
            num = clusters[cluster_id - 1]
            i_cursor.insertRow([cluster_buffer, num])
# clip the cluster buffers with the constraining fc
cluster_boundaries = arcpy.analysis.Clip(cluster_buffers, constraining_fc, "memory/ClusterBoundaries")
# randomly distribute the points inside the cluster boundaries
arcpy.management.CreateRandomPoints(output_folder, output_name, cluster_boundaries, None, "NumOfPoints", min_point_distance)
This would be better with irregular cluster boundaries, as now it's very noticeable that they are circles. A random offset for each point could do the trick, too.
Have a great day!
Johannes
JohannesLindner
A naive approach:
Script:
import arcpy
import random
# tool parameters
output_folder = ""
clusters = []
while rest > 0:
    rest -= num
Have a great day!
Johannes
MatthewPoppleton
Hi Johannes,
Thank you for your response, this is a neat way of doing it!
I experimented a bit and it looks like using a high cluster radius (~max 5000) with a low cluster point count (~max 50) distributes the points nicely across the study area. The overlapping makes it look a bit more natural too.
I agree the irregular boundaries would be less obvious than circles, would you be able to elaborate on how would I go about randomly offsetting the points?
Thanks again,
Matthew
JohannesLindner
Replace line 50 above with line 2 below (it just stores the result in a variable), move the offset parameters to the rest of the parameters for ease of access.
out_fc = arcpy.management.CreateRandomPoints(output_folder, output_name, cluster_boundaries, None, "NumOfPoints", min_point_distance)
# randomly offset each point
min_offset = 0
max_offset = 2000
with arcpy.da.UpdateCursor(out_fc, ["SHAPE@XY"]) as u_cursor:
    for p in u_cursor:
        x, y = p
        dx = random.randint(min_offset, max_offset) * random.sample([-1, 1], 1)[0]
        dy = random.randint(min_offset, max_offset) * random.sample([-1, 1], 1)[0]
        new_p = [x + dx, y + dy]
        u_cursor.updateRow([new_p])
before:
after (with quite high offset values):
Have a great day!
Johannes
JohannesLindner
Regarding irregular cluster shapes:
This would be an easy way to generate irregular (but always convex) buffer shapes:
def irregular_buffer(point_geometry, min_dist, max_dist, num_points):
    points = []
    for i in range(num_points):
        angle = random.randint(0, 359)
        dist = random.randint(min_dist, max_dist)
        points.append(point_geometry.pointFromAngleAndDistance(angle, dist).firstPoint)
    multipoint = arcpy.Multipoint(arcpy.Array(points), spatial_reference=point_geometry.spatialReference)
    return multipoint.convexHull()
The num_points argument controls how much the buffer shapes resemble a circle. Higher value -> more circle-like.
num_points = 5:
num_points = 10:
num_points = 30:
To use this method, replace lines 41-42 in my original answer with this:
            cluster_buffer = irregular_buffer(cluster_center, min_cluster_radius, max_cluster_radius, 5)
Which indeed results in more irregular clusters:
And you can still add a random offset at the end.
Have a great day!
Johannes
MatthewPoppleton
This is great, thanks again for your help!
