Format symbol label text
4624
10
05-20-2019 07:05 AM
Zeke
Honored Contributor
In ArcGIS Pro, is it possible to format the legend label text? I found this instruction - 'Format numbers in legend labels', but 1) I'm not trying to format numbers, and 2) under Advanced symbol options the only option available is Feature level masking
What I'm trying to do is format mg/m3 to µg/m3, as in 0.002 µg/m3 for the legend label. Thanks.
edit: I was able to get all except the superscript by copy -> paste. Anyway to do that?
edit 2: I ended up putting 3 in as its own text and superscripting that. Not elegant, but works.
RobertBorchert
Honored Contributor
Cannot you just type in µ in the label in the table of contents and that should come across to the legend
Zeke
Honored Contributor
I was able to get that character by copy/paste, but now want to get the 3 as superscript.
RobertBorchert
Honored Contributor
Use the ASCII character format.
press these keys while holding down <Alt>
0 1 7 9
³ as a superscript 3
RobertBorchert
Honored Contributor
Here is one of my favorite tips.  Create a spreadsheet and populate the first column with numbers 33 through 255
There are 255 characters you computer recognizes but the first 32 are things like carriage return.
Use any Roman Font.  I use Cambria
In the first row put in the name of the Font
in the second column ( using the same font)
put in the formula
=Char(A2)
The first number in A is 33 so the result will be !
216 will be   Ø which is one I use a lot also.
I made a spreadsheet about 15 years ago like this that also contains all the ESRI and NISC fonts as well as wing/web dings
I printed it out on 11"x 17" paper and have a quick and easy reference of all ESRI Fonts for symbol purposes.
Zeke
Honored Contributor
Thanks again. That didn't work for me, however. No character appeared. I ended up putting 3 in as its own text and superscripting that. Not elegant, but works.
RobertBorchert
Honored Contributor
Are you on an Apple or Linux machine? it should work with any windows machine.
no spaces between the numbers.
Try it without the leading zero
When I do it without the zero I get
│ instead of ³
Zeke
Honored Contributor
No, Windows 10. I'll try it w/o the zero.
RobertBorchert
Honored Contributor
I use the Ø a lot to for labeling number of phases for cabinets.
And I write into the label expression sometimes to change the font and show a different character. like number 059 in AmFM Gas that is a right facing arrow to indicate a number range as part of the label.
Try  it in word or notepad first.  It could be a computer thing.
RobertBorchert
Honored Contributor
