Forest-Based Classification and Regression Raster problems
809
06-20-2024 09:07 AM
LisaDygert1
I am creating a Forest-Based Classification and Regression analysis and am running into problems.  One of the raster datasets (DrainageIndex) has a categorical field for drainage index classes.  The tool appears to use a different field (rowID) instead of the drainage class field.  The tool does not appear to allow me to select which field I want to use and ArcGIS Pro 3.0 is not allowing me to rename or change the rowID field.  Even if I hide the field, the tool still tries to use that instead of the drainage class (drainagecl) field.  I also tried to export to a new raster, but that didn't work either.
This creates an error because there are more than 60 'category' values in the rowID field.  I really want to be able to use this raster dataset.  Any ideas of how I can get the tool to use the field I want?
Also, what values are recommended after training to indicate that the analysis was valid and the data that was used is a good fit?
Thanks in advance for any assistance.
Lisa D.
