fix 'is closed 3d' in ArcPRO3
1004
08-12-2022 03:14 AM
SamanthaGoodchild-Brown
Sorry if this is the wrong location. Got tired of trying to find the correct one.
The tool in the title is not working the same in arcmap 10.7 vs arcPRO3. I have a dataset of 202k records. In arcmap I get 309 of 'no'. In arcmap pro3 the same feaclass in the same gdb gets over 14 k 'no' results. I should be getting 309.
Tags (1)
KoryKramer
Esri Esteemed Contributor
Hi @SamanthaGoodchild-Brown Sorry to hear that you're seeing a difference in this tool's output when comparing between ArcMap and ArcGIS Pro. I would recommend contacting Technical Support to investigate and submit an issue to the development team if needed. Thank you!
