Fiona not importing within arcgispro-py3 clone environment
1345
01-31-2024 03:19 PM
SubramanianSankaranarayanan
Steps followed,
  • Installed ArcGISPro 3.2.0
  • Opened 'Package Manager'
  • Cloned the base environment: arcgispro-py3 as arcgispro-py3-clone-1
  • Under 'Add Packages', installed 'geopandas 0.14.2'
Geopandas has dependency in Fiona, therefore fiona 1.9.5 was also installed. I tried to import fiona and I am hit with the following error.
ImportError                               Traceback (most recent call last)
In  [7]:
Line 7:     import fiona
File C:\Users\subramanians\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\fiona\__init__.py, in <module>:
Line 41:    from fiona._env import (
ImportError: DLL load failed while importing _env: The specified procedure could not be found.
# packages in environment at C:\Users\subramanians\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1:
# Name Version Build Channel
aiofiles 22.1.0 py39haa95532_0
aiosqlite 0.18.0 py39haa95532_0
anyio 3.5.0 py39haa95532_0
appdirs 1.4.4 pyhd3eb1b0_0
arcgis 2.2.0.1 py39_39 esri
arcgispro 3.2 0 esri
arcpy 3.2 py39_arcgispro_49690 [arcgispro] esri
arcpy-base 3.2 py39_49690 esri
argon2-cffi 21.3.0 pyhd3eb1b0_0
argon2-cffi-bindings 21.2.0 py39h2bbff1b_0
arrow-cpp 12.0.0 2 esri
asttokens 2.0.5 pyhd3eb1b0_0
attrs 23.1.0 py39haa95532_0
azure-core 1.12.0 py_0 esri
azure-storage-blob 12.8.0 py_0 esri
babel 2.11.0 py39haa95532_0
backcall 0.2.0 pyhd3eb1b0_0
beautifulsoup4 4.12.2 py39haa95532_0
black 22.1.0 py39_3 esri
blas 1.0 mkl
bleach 4.1.0 pyhd3eb1b0_0
blinker 1.4 py39haa95532_0
blosc 1.21.3 h6c2663c_0
boost-cpp 1.82.0 h59b6b97_2
bottleneck 1.3.5 py39h080aedc_0
branca 0.6.0 py39haa95532_0
brotli 1.0.9 h2bbff1b_7
brotli-bin 1.0.9 h2bbff1b_7
brotli-python 1.0.9 py39hd77b12b_7
brotlipy 0.7.0 py39h2bbff1b_1003
bzip2 1.0.8 he774522_0
c-ares 1.19.1 h2bbff1b_0
ca-certificates 2023.12.12 haa95532_0
cachetools 4.2.2 pyhd3eb1b0_0
cairo 1.16.0 haedb8bc_5
certifi 2023.11.17 py39haa95532_0
cffi 1.16.0 py39h2bbff1b_0
cfitsio 3.470 h2bbff1b_7
cftime 1.6.2 py39h080aedc_0
chardet 4.0.0 py39haa95532_1003
charset-normalizer 2.0.4 pyhd3eb1b0_0
click 8.1.7 py39haa95532_0
click-plugins 1.1.1 pyhd3eb1b0_0
cligj 0.7.2 py39haa95532_0
cloudpickle 2.0.0 pyhd3eb1b0_0
colorama 0.4.6 py39haa95532_0
comm 0.1.2 py39haa95532_0
contourpy 1.2.0 py39h59b6b97_0
cppzmq 4.9.0 0 esri
cryptography 41.0.7 py39h89fc84f_0
cycler 0.11.0 pyhd3eb1b0_0
cytoolz 0.11.0 py39h2bbff1b_0
dask 2023.3.2 py_0 esri
dask-core 2023.3.2 py39haa95532_0
debugpy 1.6.7 py39hd77b12b_0
decorator 5.1.1 pyhd3eb1b0_0
defusedxml 0.7.1 pyhd3eb1b0_0
distributed 2023.3.2 py_0 esri
dpcpp-cpp-rt 2022.2.1 arcgispro_19741 [arcgispro] esri
entrypoints 0.4 py39haa95532_0
et_xmlfile 1.1.0 py39haa95532_0
exceptiongroup 1.2.0 py39haa95532_0
executing 0.8.3 pyhd3eb1b0_0
expat 2.5.0 hd77b12b_0
fiona 1.9.5 py39h4ed8f06_0
flake8 4.0.1 pyhd3eb1b0_1
folium 0.14.0 py39haa95532_0
fontconfig 2.14.1 h9c4af85_2
fonttools 4.25.0 pyhd3eb1b0_0
freetype 2.12.1 ha860e81_0
freexl 2.0.0 hd7a5696_0
fsspec 2023.10.0 py39haa95532_0
future 0.18.3 py39haa95532_0
gdal 3.7.0 arcgispro_py39_17195 [arcgispro] esri
geomet 1.0.0 py_0 esri
geopandas 0.14.2 py39haa95532_0
geopandas-base 0.14.2 py39haa95532_0
geos 3.8.0 h33f27b4_0
geotiff 1.7.0 h4545760_3
glib 2.69.1 h5dc1a3c_2
greenlet 3.0.1 py39hd77b12b_0
h5py 3.9.0 arcgispro_py39_1 [arcgispro] esri
hdf4 4.2.13 h712560f_2
hdf5 1.12.1 h51c971a_3
heapdict 1.0.1 pyhd3eb1b0_0
icc_rt 2022.2.1 arcgispro_19741 [arcgispro] esri
idna 3.4 py39haa95532_0
importlib-metadata 7.0.1 py39haa95532_0
importlib_metadata 7.0.1 hd3eb1b0_0
iniconfig 1.1.1 pyhd3eb1b0_0 esri
intel-cmplr-lib-rt 2022.2.1 arcgispro_19741 [arcgispro] esri
intel-fortran-rt 2022.2.1 arcgispro_19741 [arcgispro] esri
intel-openmp 2022.2.1 arcgispro_19741 [arcgispro] esri
ipykernel 6.28.0 py39haa95532_0
ipython 8.15.0 py39haa95532_0
ipython_genutils 0.2.0 pyhd3eb1b0_1
ipywidgets 7.7.2 py_0 esri
isodate 0.6.0 py_0 esri
jdcal 1.4.1 pyhd3eb1b0_0
jedi 0.18.1 py39haa95532_1
jinja2 3.0.3 pyhd3eb1b0_0
joblib 1.2.0 py39haa95532_0
jpeg 9e h2bbff1b_1
json5 0.9.6 pyhd3eb1b0_0
jsonschema 4.19.2 py39haa95532_0
jsonschema-specifications 2023.7.1 py39haa95532_0
jupyter_client 6.1.12 pyhd3eb1b0_0
jupyter_console 6.4.2 py_0 esri
jupyter_contrib_core 0.4.0 py_0 esri
jupyter_contrib_nbextensions 0.6.0 py_2 esri
jupyter_core 5.5.0 py39haa95532_0
jupyter_events 0.8.0 py39haa95532_0
jupyter_highlight_selected_word 0.2.0 py_4 esri
jupyter_latex_envs 1.4.6 py_5 esri
jupyter_nbextensions_configurator 0.4.1 py_3 esri
jupyter_server 1.23.4 py39haa95532_0
jupyter_server_fileid 0.9.0 py39haa95532_0
jupyter_server_ydoc 0.8.0 py39haa95532_1
jupyter_ydoc 0.2.4 py39haa95532_0
jupyterlab 3.6.3 py39haa95532_0
jupyterlab_pygments 0.2.2 py39haa95532_0
jupyterlab_server 2.25.1 py39haa95532_0
jupyterlab_widgets 3.0.9 py39haa95532_0
kealib 1.5.0 hde4a422_1
keyring 23.4.0 py39_0 esri
kiwisolver 1.4.4 py39hd77b12b_0
krb5 1.21.1 0 esri
lcms2 2.12 h83e58a3_0
lerc 3.0 hd77b12b_0
libabseil 20230125.3 0 esri
libboost 1.82.0 h3399ecb_2
libbrotlicommon 1.0.9 h2bbff1b_7
libbrotlidec 1.0.9 h2bbff1b_7
libbrotlienc 1.0.9 h2bbff1b_7
libcurl 8.5.0 h86230a5_0
libdeflate 1.17 h2bbff1b_1
libffi 3.4.4 hd77b12b_0
libgdal 3.6.2 h9a21643_4
libiconv 1.16 h2bbff1b_2
libkml 1.3.0 h63940dd_7
libnetcdf 4.8.1 h6685c40_4
libpng 1.6.39 h8cc25b3_0
libpq 12.15 h906ac69_0
libprotobuf 3.21.12 0 esri
libsodium 1.0.18 h62dcd97_0
libspatialindex 1.9.3 h6c2663c_0
libspatialite 5.1.0 hbdd3232_0
libssh2 1.10.0 he2ea4bf_2
libthrift 0.18.1 0 esri
libtiff 4.5.1 hd77b12b_0
libutf8proc 2.8.0 0 esri
libwebp-base 1.3.2 h2bbff1b_0
libxml2 2.10.4 h0ad7f3c_1
libxslt 1.1.37 h2bbff1b_1
libzip 1.8.0 h289538f_1
locket 1.0.0 py39haa95532_0
lxml 4.9.3 py39h09808a7_0
lz4 3.1.3 py39h2bbff1b_0
lz4-c 1.9.4 h2bbff1b_0
mapclassify 2.5.0 py39haa95532_0
markupsafe 2.1.3 py39h2bbff1b_0
matplotlib 3.6.3 py39_arcgispro_0 [arcgispro] esri
matplotlib-base 3.6.3 py39_arcgispro_0 [arcgispro] esri
matplotlib-inline 0.1.6 py39haa95532_0
mccabe 0.7.0 pyhd3eb1b0_0
minizip 4.0.3 hb68bac4_0
mistune 2.0.4 py39haa95532_0
mkl 2022.2.1 arcgispro_19755 [arcgispro] esri
mkl-service 2.4.0 py39_arcgispro_2 [arcgispro] esri
mkl_fft 1.3.1 py39_arcgispro_5 [arcgispro] esri
mkl_random 1.2.2 py39_arcgispro_5 [arcgispro] esri
mpmath 1.2.1 py39haa95532_0
msgpack-python 1.0.3 py39h59b6b97_0
msrest 0.6.21 py_0 esri
munkres 1.1.4 py_0
mypy_extensions 0.4.3 py39haa95532_1
nbclassic 1.0.0 py39haa95532_0
nbclient 0.8.0 py39haa95532_0
nbconvert 7.10.0 py39haa95532_0
nbformat 5.9.2 py39haa95532_0
nest-asyncio 1.5.6 py39haa95532_0
netcdf4 1.6.4 py39_arcgispro_0 [arcgispro] esri
networkx 3.1 py39haa95532_0
nlohmann_json 3.11.2 0 esri
nose 1.3.7 pyhd3eb1b0_1008
notebook 6.4.12 py_0 esri
notebook-shim 0.2.3 py39haa95532_0
ntlm-auth 1.4.0 py_0 esri
numexpr 2.8.4 py39_2 esri
numpy 1.22.4 py39_0 esri
numpy-base 1.22.4 py39_0 esri
oauthlib 3.2.0 py39_0 esri
olefile 0.46 pyhd3eb1b0_0
openjpeg 2.4.0 h4fc8c34_0
openpyxl 3.0.10 py39h2bbff1b_0
openssl 3.0.12 h2bbff1b_0
orc 1.8.3 0 esri
packaging 23.1 py39haa95532_0
pandas 2.0.3 py39h4ed8f06_0
pandocfilters 1.5.0 pyhd3eb1b0_0
parso 0.8.3 pyhd3eb1b0_0
partd 1.2.0 pyhd3eb1b0_1
pathspec 0.9.0 py_0 esri
patsy 0.5.3 py39haa95532_0
pcre 8.45 hd77b12b_0
pcre2 10.42 h0ff8eda_0
pefile 2022.5.30 py39haa95532_0
pickleshare 0.7.5 pyhd3eb1b0_1003
pillow 9.5.0 py39_1 esri
pip 23.3.1 py39haa95532_0
pixman 0.40.0 h2bbff1b_1
platformdirs 3.10.0 py39haa95532_0
pluggy 0.13.1 py39haa95532_0
poppler 22.12.0 h0bf3bde_3
poppler-data 0.4.11 haa95532_1
pro_notebook_integration 3.2 py39_5 esri
proj 9.3.1 ha107b6e_0
prometheus_client 0.14.1 py39haa95532_0
prompt-toolkit 3.0.43 py39haa95532_0
prompt_toolkit 3.0.43 hd3eb1b0_0
protobuf 3.21.12 py39_0 esri
psutil 5.9.0 py39h2bbff1b_0
pure_eval 0.2.2 pyhd3eb1b0_0
pyarrow 12.0.0 py39_4 esri
pybind11 2.10.4 1 esri
pybind11_json 0.2.13 0 esri
pycodestyle 2.8.0 pyhd3eb1b0_0
pycparser 2.21 pyhd3eb1b0_0
pyflakes 2.4.0 pyhd3eb1b0_0
pygments 2.15.1 py39haa95532_1
pyjwt 2.4.0 py_1 esri
pylerc 4.0 py_0 esri
pyodbc 4.0.34 py39hd77b12b_0
pyopenssl 23.2.0 py39haa95532_0
pyparsing 3.0.9 py39haa95532_0
pypdf 3.15.0 py_1 esri
pypdf2 2.10.5 py39haa95532_0
pyproj 3.6.1 py39h8d66fa9_0
pyrsistent 0.20.0 py39h2bbff1b_0
pyshp 2.1.3 pyhd3eb1b0_0
pysocks 1.7.1 py39haa95532_0
pyspnego 0.8.0 py39h2bbff1b_2
pytest 7.2.0 py39_0 esri
python 3.9.18 0 esri
python-certifi-win32 1.6 py_0 esri
python-dateutil 2.8.2 pyhd3eb1b0_0
python-fastjsonschema 2.16.2 py39haa95532_0
python-gssapi 1.8.2 py39_0 esri
python-json-logger 2.0.7 py39haa95532_0
python-tzdata 2023.3 pyhd3eb1b0_0
python_abi 3.9 1_cp39 esri
pytz 2023.3.post1 py39haa95532_0
pywin32 305 py39h2bbff1b_0
pywin32-ctypes 0.2.0 py39haa95532_1000
pywin32-security 306 py39_2 esri
pywinpty 2.0.10 py39h5da7b33_0
pyyaml 6.0.1 py39h2bbff1b_0
pyzmq 25.1.2 py39hd77b12b_0
qhull 2020.2 h59b6b97_2
re2 2023.06.02 0 esri
referencing 0.30.2 py39haa95532_0
regex 2022.7.9 py39h2bbff1b_0
requests 2.31.0 py39haa95532_0
requests-gssapi 1.2.3 py_2 esri
requests-kerberos 0.12.0 0 esri
requests-negotiate-sspi 0.5.3 py39_0 esri
requests-oauthlib 1.3.0 py_0
requests-toolbelt 1.0.0 py_0 esri
rfc3339-validator 0.1.4 py39haa95532_0
rfc3986-validator 0.1.1 py39haa95532_0
rpds-py 0.10.6 py39h062c2fa_0
rtree 1.0.1 py39h2eaa2aa_0
ruamel.yaml 0.17.21 py39h2bbff1b_0
ruamel.yaml.clib 0.2.6 py39h2bbff1b_1
saspy 4.3.2 py_1 esri
scikit-learn 1.3.0 py39h4ed8f06_1
scipy 1.7.3 py39_3 esri
seaborn 0.12.2 py39haa95532_0
send2trash 1.8.2 py39haa95532_0
setuptools 68.2.2 py39haa95532_0
shapely 2.0.1 py39hd7f5953_0
six 1.16.0 pyhd3eb1b0_1
snappy 1.1.10 h6c2663c_1
sniffio 1.3.0 py39haa95532_0
sortedcontainers 2.4.0 pyhd3eb1b0_0
soupsieve 2.5 py39haa95532_0
sqlalchemy 1.4.51 py39h2bbff1b_0
sqlite 3.41.2 h2bbff1b_0
stack_data 0.2.0 pyhd3eb1b0_0
statsmodels 0.14.0 py39h9128911_0
swat 1.13.2 py39_0 esri
sympy 1.9 py39_1 esri
tblib 1.7.0 pyhd3eb1b0_0
terminado 0.17.1 py39haa95532_0
testpath 0.6.0 py39haa95532_0
threadpoolctl 2.2.0 pyh0d69192_0
tiledb 2.3.3 hd8964de_3
tinycss2 1.2.1 py39haa95532_0
toml 0.10.2 pyhd3eb1b0_0
tomli 2.0.1 py39haa95532_0
toolz 0.11.2 pyhd3eb1b0_0
tornado 6.3.3 py39h2bbff1b_0
tqdm 4.65.0 py39hd4e2768_0
traitlets 5.7.1 py39haa95532_0
typed-ast 1.4.3 py39h2bbff1b_1
typing-extensions 4.9.0 py39haa95532_1
typing_extensions 4.9.0 py39haa95532_1
tzdata 2023d h04d1e81_0
ujson 5.4.0 py39hd77b12b_0
uriparser 0.9.7 h2bbff1b_0
urllib3 1.26.18 py39haa95532_0
vc 14.2 h21ff451_1
vs2015_runtime 14.27.29016 h5e58377_2
wcwidth 0.2.5 pyhd3eb1b0_0
webencodings 0.5.1 py39haa95532_1
websocket-client 0.58.0 py39haa95532_4
wheel 0.41.2 py39haa95532_0
widgetsnbextension 4.0.5 py39haa95532_0
win_inet_pton 1.1.0 py39haa95532_0
wincertstore 0.2 py39haa95532_2
winkerberos 0.8.0 py39_0 esri
winpty 0.4.3 4
wrapt 1.14.1 py39h2bbff1b_0
x86cpu 0.4 py39_1 esri
xarray 2023.6.0 py39haa95532_0
xerces-c 3.2.4 hd77b12b_1
xeus 3.0.5 0 esri
xeus-python 0.15.8 0 esri
xeus-zmq 1.0.2 0 esri
xlrd 2.0.1 pyhd3eb1b0_1
xlwt 1.3.0 py39haa95532_0
xtl 0.7.5 0 esri
xyzservices 2022.9.0 py39haa95532_1
xz 5.4.5 h8cc25b3_0
y-py 0.5.9 py39hb6bf4ef_0
yaml 0.2.5 he774522_0
ypy-websocket 0.8.2 py39haa95532_0
zeromq 4.3.5 hd77b12b_0
zict 3.0.0 py_0 esri
zipp 3.17.0 py39haa95532_0
zlib 1.2.13 h8cc25b3_0
zlib-ng 2.0.7 h2bbff1b_0
zstd 1.5.5 hd43e919_0
Tags (3)
