Finding Land Surface Temperature (LST) from Landsat 9 using ArcGIS Pro
8115
02-17-2023 02:43 PM
SarahCope
Hi there,
I am trying to calculate the land surface temperature in Omaha, Nebraska. I have obtained data from the USGS Earth Explorer that was acquired in July 2022 with the hopes of getting a range of summer temperatures that are typical to the area. However, when completing the calculations, I get temperatures that would align closer to the winter months (5 degrees celsius to negative five degrees celsius). The tutorial I have been following is based out of Eastern Africa, (https://www.youtube.com/watch?v=YXBat9MNh9E). While I pull a lot of my own numbers from the text file included with the data, some of the numbers are provided by the video creator through their equations. Does anyone know if these numbers would change depending on where you're at in the world? Or have any idea why I would continue to get strange temperatures for the time and region upon completing the calculations? Thanks!
In this video you will learn how to obtain Land Surface Temperature (LST) of LANDSAT 9 using ArcGIS Pro. If you like this video, you can SUBSCRIBE this channel to get notified of new videos
sturaro
Hey Sarah, I got the exact same problem, here they say if you use the extract by mask tool in a study area you create the problem will be solved https://www.youtube.com/watch?v=EzavTBq-1wM&ab_channel=VikasGhadamode, but it didn`t work for me... I`ll probably initiate another question...
Reference paper: Estimating Land Surface Temperature Using ArcGIS Any Help Contact Mr.Vikas [email protected] WhatsApp Number= +918421031398 Special Thanks for What I am Using Software: https://amzn.to/3BO5IMF GIS BOOKS: https://amzn.to/3xmM333 Mic: https://amzn.to/3iYN77P HP ...
