Field Name “FolderPath” in Pro 2.7 stops export of kml-files
1410
12-19-2020 06:05 AM
ThomasL
Heads up if you like me have a feature class with a Field Name: “FolderPath” in ArcGIS Pro 2.7 and export it to KML!
An almost empty kml file is exported looking like this, besides the header:
<Document id="Cat1">
  <name>Cat1</name>
  <snippet></snippet>
  <description><![CDATA[map]]></description>
</Document>
</kml>
If I rename the Field Name from “FolderPath” to "test" kml export using "Layer to KML" works.
Bug report sent to ESRI: #BUG-000136600
This bug is related to BUG-000121722 and is first reported not working in ArcGIS Pro 1.3 back in 2016.
This feature works in ArcMap.
ArcMap > ArcGIS Pro still true in 2021? 🙂
