Field Calculator '*.cal' file encoding ... not '*.py'
8832
15
06-21-2017 05:01 AM
DanPatterson_Retired
The ability to save and reuse python snippets for using in the Calculate Field tools is useful (aka... the field calculator for non-ArcGIS Pro users).  A couple of questions then...
  • UTF-16-LE .... the encoding used for some reason rather than utf-8 for instance
  • UC2-2 LE BOM ... is this good enough if you use a Notepad++ file?
  • -*- coding: <encoding-name> -*-   as the first line using either the UTF or UC2 version... will that solve encoding problems with the *.cal files?
And the biggie....Why can't you use Python *.py files?
It is more out of curiosity and... I have to teach... so this is what I have to tell my students...
  • the default language used in Pro is Python...
  • Python files have a *.py file extension ...
  • except in the calculate field tool for Pro,
  • *.cal files is all you will see,
  • save your 'defs' as cal and py files if you want to use them everywhere
  • no more questions now... I have a headache
Some illumination would be useful so I can expand my bullet list.  Others that teach out there, may wish to jump in with addition missives should they have encountered any
Curtis PriceTimothy Hales‌ perhaps, or an FYI##
'68 for me, with cards... thanks Vince
Fresh ones arrive... with 10.5.1 more parameters in slope and aspect check geoprocessing section and Pro 2.0 is live
curtvprice
The help for 10.5.1 and Pro 2.0 is up, but no software yet for me on my.esri.  Probably very soon though.
This is cool: GPU processing with Spatial Analyst—Help | ArcGIS Desktop
Wow... 29 viewers, hi to the esri staff that I haven't heard of.  325 emails? must have generated some interest.
BUT
I will close this off as a discussion since it appears that the status quo will remain for some reason (legacy purposes?).
Workarounds abound ... I don't need them, but thank you.  I am more interested in finding a suitable explanations for my students without using
'.... because, that's the way it is... '
in an explanation of why python is widely adopted, except when saving in the field calculator.
Anyone at UC... ask around...
Dan
ScottDrzyzga
Thanks for posting this, for you helped me answer an unrelated question.  I had a student that used a text editor to edit a *.cal file, but on [Load], all the characters had "changed" to Chinese.  We kept trying to fix it by saving to UTF-8 or ANSI, but ... UC2-2 LE BOM.  Thanks.
While I'm here, has the big question been answered yet?  Not here, obviously, but elsewhere?
"And the biggie....Why can't you use Python *.py files?"
GIS professional and map nerd | Outdoor enthusiast | Remote Pilot (USA and Canada)
It hasn't.... and there is probably some reason beyond 'inertia', that I am not privy to.
In any event, I just keep two exact same versions, or if I just forget, I change the file extension and comment out the last 2 lines that the *cal version magically adds
__esri_field_calculator_splitter__
angle_between(!Shape!, True)
Those two lines are what populates the Expression box so that the *cal does all the work for you.
