Feature Layer's View showing empty Table in Pro, not in Online Map Viewer
1037
08-08-2024 01:57 PM
aballasiotes
I have created a hosted Feature Layer in ArcGIS Online and have been sharing editable Hosted Views with colleagues across my organization, and controlling access using Groups. The Groups allow for members to edit, and to see everything in the tables. However, while the hosted views are loading correctly in the Map Viewer in ArcGIS Online, when they try adding the hosted views to Pro, the attribute tables open as blank (but showing the geometries in the map view and the feature number is correct at the bottom of the table). Not sure I can include a
Ed_
by MVP Regular Contributor
Usually, within an organization you can also trying sharing the data via an SDE. Basically, export your layer to an SDE and that anyone in your organization who access to that SDE will be able to access the feature class in Pro.
Question | Analyze | Visualize
