Facing an unseen problem on ArcPro: Classified pixels being lost while using Con tool
1517
07-15-2020 08:34 PM
AdityaSharma1
Facing an unseen problem on ArcPro: I have a land cover raster with 24 classes, made up of square pixels with pixel side length being 313 metres. I downloaded the attribute table of this raster dataset and noted total of 752,076 pixels. Then I went about re-working the 24 classes into 4 major classes by using the 'Con' tool. When I see the attribute table of this new raster dataset with 4 classes, the number of pixels add to 704,523. This means a difference of 47,553 classified pixels emerges between the 2 datasets. Could somebody please help me understand that how are classified pixels getting lost in the process of combining the classes into 4 major ones using the 'Con' tool? Thanks.
DanPatterson
MVP Esteemed Contributor
Your con statement and classification would help to make sure that all conditions were covered
... sort of retired...
AdityaSharma1
Hi Dan.. sorry but I didn't get you. Are you asking me to share the con statement. In that case, I am attaching the 2 statements that I have exported from ArcPro. I am also attaching the PDF of the help sheet that accompanied the raster. The raster is too big to be attached here.
So I am following the steps of 'Con' implementation: -
1) Group all the Natural Land Cover classes together in the original raster and classify the grouping as Value = 1 in the new raster. In this process I combined 16 Land classes into 1 category.
2) In the raster acquired from Step 1, Group all the Human affected Land Cover together and classify it as Value = 2. In this process I combined 6 Land classes into 1 category.
3) Finally, the raster output from Step 2 had 4 classes (16 sub classes= 1, 6 sub classes = 2, two sub classes from the original raster).
Now when I sum the pixels of these 4 raster classes, they don't add up to the sum of original 24 sub classes as in the original dataset.
That's where I was wondering what could've gone wrong in a seemingly straightforward 'Con' geo-processing tool?
Aditya
