Extrusions Question: How Do You Create a Floating Polygon
1715
08-15-2019 07:18 AM
WilliamSmith6
I am trying to make a Scene in ArcGIS Pro using Extrusions. From what I have seen with extruding polygons you can only extrude from your base, but can you specify a minimum and maximum z-value that doesn't originate at the base of the data?
I want to map airspace. I have 1 polygon extruding from the base to 400' above ground level (AGL) to represent airspace a drone can fly in. Above that, E Class airspace starts at 700' AGL.  Instead of having the polygon that has the 700' start from the base and extend upward to 700', I want to have a polygon that starts at 700'  and extend upward from there. This should leave a 300' gap in between both polygons.
Is there a workflow to do this based on a field? Should I just try to draw it manually?
If not based on a field, is there some other kind of workflow to follow?
LR
See if the cartographic offset in the layer properties can do the job. Otherwise I'd suggest a procedural rule.
