Extrusion by Field is Disabled for Multipatch in ArcGIS Pro
2562
04-01-2020 10:48 AM
BillMacPherson
I'm trying to extrude by a value in an attribute field for multipatch features. It seems the Extrusion options on the Appearance tab are disabled (greyed out). This is within a local Scene.
It will let me extrude the multipatch features using the 3D handle (from there I can enter a height value) but I would like to use an attribute field instead. It will let me extrude a polygon feature class using an attribute field but not the multipatch feature class.
This is not an imported scene.
I'm in ArcGIS Pro 2.5.
The multipatch layer has a horizontal and vertical spatial reference.
I've been using this as a reference Define height characteristics for layers
Thanks
Bill
Scott_Harris
Hi Bill,
You can only extrude polygons, not multipatches, but this tip in the doc should help:
Create multipatch features—ArcGIS Pro | Documentation
Scott
Scott_Harris
Hi Bill,
Scott
Scott_Harris
