Extrude line features at various elevations at ends
2999
01-20-2016 08:09 PM
Arun_PrasadRamanujadoss
Hi friends..
I have a utility line feature which need to be extruded at various elevations, like one end of line is 100mRL and other end is at 110mRL. Is there any options to add diffrent elevations for start and end of the same line feature?
Thanks
Arun
Hi Friends,
          This is the method I done to solve this issue, I exported the line into Points base on vertices using "Feature Vertices to Points" tool and then calculated the "Z value" of each points based on their Gradient. I know it is hectic.
          Then I manually entered those Z values into the each verices using "Edit verices" option.
          This is the solution I found, It is long and impossible for large Quantiity of features, but for small region It will get the job done.
          Please let me know if, there is any simpler solutions...
