Extracting Polygons from Basemap
443
05-28-2026 10:55 AM
TrevorDunne10
Is there any way I can extract the green area from the basemap to a polygon? Trying to find an quicker/easier solution than manually tracing it.
KrishnaDaravath
You can’t directly convert a basemap into a polygon because basemaps are just images, not real vector data.
If you need that green area as a polygon, you have 3 options:
  • Manually trace it (Sketch tool)
  • Use imagery and run classification tools
  • Find a land cover dataset that already has boundaries
If it’s just a quick job, manual tracing is usually the fastest.
TrevorDunne10
Thank you!
Robert_LeClair
Esri Esteemed Contributor
As stated above, no.  But this Learn ArcGIS lesson provides another workflow to do something similar - Extract high-resolution land cover with GeoAI | Documentation
