extract values to points arcgis pro
1084
03-05-2020 09:43 AM
Mark_Medina
I am having an issue with the Extract Values to Points in ARCGIS pro. I have followed the instructions on how to use the tool but for some reason the values have been coming out extremely wrong.  The Elevation on the slope of this hill is between 260 and 280. The  raster value comes out as between 79-86. Is this normal for pro? I used this tool on ArcMap and got the right elevations. I just want to know why it didn't work in Arcgis Pro?
In the picture you will see that the ground elevation, which I derived from Google earth, at the end you will see the RasterValue which is off.
I've tried it with both interpolate values and append check on and off and every variation between.
Before I forget, both the raster and the point feature layer are in the same coordinate system. Its not a lot about of points, just want to know for the future. Thank you
