Extract values from tiff
4630
12-20-2021 07:51 AM
Labels (2)
JoaoPinto
Hello Everbody,
I georeferenced a Tiff, but after this, i found a problem with extracting the values ​​(quoted points).
Any solution to extract the quoted points from the tiff?
I leave an image below with an example(red circle) of what I want to extract, but the values are many.
best Regards
DanPatterson
MVP Esteemed Contributor
two options
Extract Multi Values to Points (Spatial Analyst)—ArcGIS Pro | Documentation
or if it is because they are closely spaced then you will need to use one of the other extraction tools
An overview of the Extraction toolset—ArcGIS Pro | Documentation
... sort of retired...
JayantaPoddar
Heads-up digitization could be your fastest option here.
Think Location
Luke_Pinner
MVP Regular Contributor
Are you saying you have a tif with the values as written text from a scanned map and you want to extract those text values to points with numeric values?
I don't think that is feasible.  I agree with @JayantaPoddar you might have to digitise manually.
