Export layer file from ArcGIS Pro to ArcGIS solution ?
2080
08-21-2017 07:53 AM
DEAF_PROBERT_68
Honored Contributor
Has  anyone any luck getting their layer file saved from ArcGIS Pro into ArcGIS 10.3.1 .
I went through the ArcGIS Pro group section  and found this somebody question on about saving Layer file from ArcGIS Pro to ArcGIS 10.x ...
saving LYR file from arcgis pro
Before you answer to my question ..
I worked all the files and stuff done on ArcGIS 10.3.1 and tried to set it up a symbology that looks like this :
  < -- see the symbology with E and X . that is the one I am working on ...
Problem when you use it in ArcGIS 10.3.1, it can be very difficult to make some modify through the Layer's properties and it can take a lot of my time and it's time-consuming and toll on me.
So my alternative was to take a try in ArcGIS Pro and this really help me a lot and make so much easier ! Problem is How do I export back in ArcGIS 10.3.1
is there any alternative way to do this ?
As of August 21, 2017,
ArcGIS 10.3.1
ArcGIS Pro 1.4
DEAF_PROBERT_68
Honored Contributor
I was able to get it to work ; however, it is not showing up....Hmmmmmm
DEAF_PROBERT_68
Honored Contributor
#^%%&^(*&   it came out as a picture marker !!!!!
DEAF_PROBERT_68
Honored Contributor
Never mind I went back and do my best in ArcGIS 10.3.1 and fix it. It looks much better.
It would have been nice if ESRI could stand up and change their ArcGIS Pro to set all the same as 10.3 and others.
Too bad we have to suffer it !
