Export extent different than animation
3313
11
02-24-2023 04:33 PM
KevinRybacki
I am using Ac GIS Pro and I have set up animations while manually labeling some dams on the river using the overlay option with an arrow and paragraph.  Looks great when I animate it but as soon as I export it to a video the map extent changes (why, I have no idea) so there are parts of the river displaying that I do not want and the labels are way off the mark.  Why go through making the animation just the way you want it if it completely changes when you export it?! Is there any way to export the animation that was set up?  The lock view size does not help with this to the extent I need it to.
Please help,
Thanks!!
HugoWortel
Same here. Following...
ToyotaT18
I worked out that if I set a custom export resolution of 1200 x 1000, then the map extent does not change (much). It means I'm restricted to outputting a very square-ish video, but at least I can be sure of what the view will be.
Actually I'm changing this advice as I'm now getting it zooming out again, so it's not a reliable workaround.
