Excel Tables in ArcGIS Pro
9578
11
02-21-2019 06:36 AM
MichelleCouden
I am trying to add an excel table to a map in ArcGIS Pro. It is a 2010 excel file. Simple no macros or anything. It won't load. I have tried everything from the help menu. Am I having problems because we only have ArcGIS Pro 2.1??? I have attached the excel file I am trying to use.
Tags (1)
JoeBorgione
Good habit to have!
DanPatterson_Retired
field names shouldn't begin with numbers
you had a whole load of 'errors' in the T_Flag column.  I 'fixed' those by copying to a new field defined as 'Text', then copied the values back over the original field (so CHECK THEM!!! )
But Excel To Table in ArcGIS Pro worked
see the attached.  I called it 'stuff', so as not to confuse it with the original.
