Excel Legends
2035
05-04-2023 06:24 AM
SLouq
by MVP Alum
I have Legend which I made in Excel to use in an ArcGIS Pro map. Is there a way to make the Excel grid lines, the gray lines, transparent so they don't show when the legend is in my ArcGIS Pro map
Tags (1)
MrRamonG
In addition to Luci's suggestion, you may also want to give the cells, in Excel, a white fill.
Layer Slayer
LuciHawkins
Have you tried turning "Gridlines" off under the View menu in Excel before copying and pasting into ArcPro
SLouq
by MVP Alum
nope
I'll give that a try and see if it does what I want.
Thanks
MrRamonG
Layer Slayer
SLouq
by MVP Alum
That worked!
