ESRI Imagery downloaded as Tile Package
981
09-30-2024 03:32 PM
ZoeTysonLID1989
I have been trying to download high resolution imagery (ideally from ESRI) as vector tiles that we can host or sideload for offline maps in Field Maps. Ideally this would be at least county sized files that zoom into a building level clearly. ESRI doesn't seem to allow a lot of their imagery to be downloaded this way even with an imagery layer that is labelled "for Export". The download map button works but I cannot get the county size and resolution to the ideal level.
I know that you can download offline maps for Field Maps through ESRI without hosting or sideloading which is what we currently do, but we have been having some issues and so wanted to explore other options. I am wondering if anyone has encountered this problem or has a solution/work around suggestion.
Thanks!
EmikoCondeso
Wondering if this was ever resolved for you?  I have a similar question.
bknox
Did you ever figure this one out? We are struggling with our offline downloads timing out using the ESRI suggested imagery basemaps (specifically for offline downloads). We would prefer to sideload but, as a small local government, we don't have the means to produce our own hi-res imagery
