Error message "expected proper name; state : startOfArray; buffer : :"
2433
11-23-2021 09:29 AM
Labels (2)
adfhaiti
I have a point data layer that I've brought into ArcGIS Online from Fulcrum (the data collection app we use). The layer works just fine in ArcGIS Online Map Viewer. The points show up as expected and I can view the table without a problem. When I open the save layer or map in ArcGIS Pro, it doesn't load the points (I can't see them) and when I try to open the attribute table I get this error message: "expected proper name; state : startOfArray; buffer : :"
I've attached two screenshots. One shows the layer working just fine in a ArcGIS Online Map, and the other shows the error I get when I try to load it in ArcGIS Pro.
adfhaiti
It seems there are some more complications with the layer. It acts weird inside of ArcGIS online also. I can't create any charts on the data and when I try to export the map as a PDF it doesn't include the points in the export.
