Error Cloning Python Environment Pro 3.4.3
1999
10
01-08-2026 09:17 AM
EricSimpson96
I am attempting to clone my Python environment on a new PC running ArcGISPro 3.4.3, and I get the following error:
> "C:\Program Files\ArcGIS\Pro\bin\Python\Scripts\conda.exe" create --clone "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3" -p "C:\Users\simpson_e\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone" --no-shortcuts --pinned --yes
CondaHTTPError: HTTP 404 NOT FOUND for url <https://conda.anaconda.org/esri-build/win-64/vc-14.38-0.conda>
Elapsed: 00:00.157106
CF-RAY: 9bad35408b1ba548-MIA
An HTTP error occurred when trying to retrieve this URL.
HTTP errors are often intermittent, and a simple retry will get you on your way.
CondaHTTPError: HTTP 404 NOT FOUND for url <https://conda.anaconda.org/esri-build/win-64/vs2015_runtime-14.38.33130-0.conda>
Elapsed: 00:00.185534
CF-RAY: 9bad35408f058c20-MIA
Source: C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3
Destination: C:\Users\simpson_e\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone
Packages: 280
Files: 15
Copying pinned file from C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\conda-meta\pinned to C:\Users\simpson_e\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\conda-meta\pinned
Downloading and Extracting Packages: ...working... done
Cleaning up...
Destination folder removed.
I tried going to the URL that is indicated as having a 404 error, and it is indeed blank. Is there an alternative method I can try? It seems that Anaconda is changing their website.
Thank you!
StuartPowling
After several hours of AI telling me to clone using conda in python ... it didn't suggest copy and paste. Works absolutely fine. Thank you.
