ERROR 999998:Something unexpected caused the tool to fail
2892
04-08-2023 01:27 PM
NatalyaVargas
Hi, my name is Natalya, I'm struggling with an error and I don't know how to resolve it, I have an educational trial with ArcGIS Pro 3.0.3 version. This is the error: Kernel Interpolation With Barriers ===================== Parameters Input features GENERALTUR1_ExcelToTable1_XYTableToPoint Z value field F44958 Output geostatistical layer Output raster D:\Natalya\UdC NRV\X SEMESTRE\TESIS\ArcGIS\FEB23 Output cell size 1,11102467738817E-05 Input absolute barrier features laguito Kernel function POLYNOMIAL5 Bandwidth Order of polynomial 1 Ridge parameter 50 Output surface type PREDICTION ===================== Environments Extent -75,5622757639169 10,3944783515915 -75,5575994219948 10,397255913285 GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]] ===================== Messages Start Time: sábado, 8 de abril de 2023 2:37:53 p. m. Bandwidth = 0,0007283047360968592 ERROR 999998: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds. Failed to execute (KernelInterpolationWithBarriers). Failed at sábado, 8 de abril de 2023 2:37:53 p. m. (Elapsed Time: 0,43 seconds) Any suggestion will be really helpful for me.
DavidPike
MVP Notable Contributor
Can you share your input parameters?  WGS84 jumps out at me, do you have Planar or Geodesic set?
NatalyaVargas
Hi, David. I'm working with planar set and a .shp document that I did in qgis
DavidPike
I'd test on a subset where everything is in the same planimetric xy coordinate system.  Something is in WGS84 so I'd try to reproject that.
ChristopherCounsell
MVP Frequent Contributor
Error 999998 is a generic error that means something when wrong at an operating system level, and ArcGIS Pro does not have a message for it.
Raster/analysis processing can be very intensive and finicky with Windows. Would suggest:
  • Try it with a smaller sample (small CSV, small extent). This will help show your tool is running correctly
  • Increase cell size of output raster
  • Close other applications to free up computer resources
  • Ensure the inputs and outputs are on a local PC drive and not a external USB or cloud storage like OneDrive
Is the 'D' drive a thumbdrive? Can you work on a hard drive like C, then copy results to your D drive? Best to put whole ArcGIS Pro project on the computer and copy it off.
