Enforcing Upper Case text in attribute
3451
08-19-2021 10:59 AM
LorindaGilbert
Hi All,
Is there an attribute rule or a setting in the egdb that would enforce that all text entered in an attribute field would be upper case - no matter how it was typed?
Lorinda
JoeBorgione
In the the first sequence you haven't done anything to the original value of  your variable 'cmts'.  You do in the second sequence. Very cool.
var cmts = $feature.Comments
var Uc = Upper(cmts)
return Uc;
Here I create a new variable and return it.  Not as cool. No need to create a variable because you use the object properties.
That should just about do it....
JoeBorgione
In the code below, I concatenate a bunch of attributes and then use the proper() function to make the final text pretty.  Use the upper () function instead in line 12...
var values = [$feature.NAME, $feature.POSTTYPE, $feature.POSTDIR]
var combined_value = [];
// Loop through the field values and test if they are null or empty strings
// If they are not null or empty add them to an array
for (var i in values) {
    var value = values[i];
    if (IsEmpty(value)) continue;
    combined_value[Count(combined_value)] = value
// Return the field values concatenated with a space between
return proper(Concatenate(combined_value, " "));
 This fires on Insert and Update.
LorindaGilbert
Hi Joe,
This is the code that I used and published, but it wasn't giving me upper case text when I test in neither ArcPro nor in the web app.  I checked, the column name is proper name - Comments.
          Upper(cmts)
     return cmts;
So I changed it to be this:
     return Upper(cmts);
And it worked - go figure.
Thanks for the validation that I was using the correct item, just slightly wrong syntax.
Lorinda
JoeBorgione
return Uc;
