Edit Converted Graphic Lables in Pro
2137
09-07-2022 09:54 AM
2Quiker
Using Pro I've converted a layers labels to graphics, can they converted graphics be edited, if so how? I know they can be edited if labels are converted to Annotation. I have tried to to edit them in the layout and have tried activating the map frame. This was easily done in Arcmap.
Thanks.
wayfaringrob
Honored Contributor
Since they are graphics, they'll need to be selected with the graphic select tool (same tool used on layouts) in either the map or inside an activated data frame. Different from the regular (feature) select tool, it's located on the graphics tab by default but can be added to your quick access toolbar via right click.
wayfaringrob
Honored Contributor
2Quiker
I was trying to so this in the layout view, THANKS FOR THE REPLY.
