Dynamic text failed
1037
11-07-2022 05:41 AM
LauraFlottow
Hey everybody,
I want to use a dynamic text to show the amount of the values in the actual card frame. The dynamic text don't display the values right. For example there are findpoints of three birds of the same species in the card frame. The dynamic text have to show the number of three, but it display only two. Why?
TomBole
Hi Laura,
Can you provide details? Perhaps screenshots of the map frame (I'm assuming that this is what is meant by "card frame") and the properties of the dynamic text element (what field is being used).
It is possible that you are conducting a count on a field where one of the features that has a null value. It is also possible that you are running into a bug. Without actually seeing your data I would only be guessing at why you are not getting the result you expect.
Can you contact Esri Support? They are better equipped to handle troubleshooting steps and gather bug data. They can be contacted at https://support.esri.com/en/contact-tech-support.
Tom
