Dragging Catalog item to Contents pane doesn't always work
2249
04-13-2023 09:43 PM
Bud
Esteemed Contributor
ArcGIS Pro 3.1.1
Most of the time, dragging a Catalog item to the Contents pane works as expected. But sometimes when I attempt to drag an item, the Contents pane won't allow me to drop the item (the rectangle in the Contents pane that indicates an item can be dropped doesn't show up).
Video:
(The yellow circle around the mouse pointer indicates that the mouse button has being clicked/is being dragged.)
Sometimes, the issue is that I've accidently single-clicked the item name and put it into rename-mode. Which seems to prevent dragging & dropping. I don't know if that's operator error or not.
But other times, the dragged item simply can't be dropped. Such as the first attempt in the video.
Has anyone else had that issue? Have you been able to narrow it down to a specific scenario/root cause?
Thanks.
Full video: Mobile GDB spatial database view — Can't open attribute table directly using 'Open Table' in Catalog. I tried reproducing the steps in that video but didn't see the drag-and-drop issue this time.
Bud
Here's another example (ArcGIS Pro 3.1.1):
Dragging the STRLN_ROUTE FC from Catalog to Contents doesn't work on the first try.
Full video source: https://community.esri.com/t5/arcgis-pro-ideas/make-route-event-layer-output-layer-s-default-name/id...
Bud
Here's another example. ArcGIS Pro 3.3.0; file geodatabase.
Unfortunately, I don't know what the root cause is or what the repeatable steps would be.
To quote the Trailer Park Boys: "Sometimes she goes, and sometimes she don't."
FU_ESRI
This happens to me all the time and seems to be one of the oldest and most common bugs in the myriad of flaws in ArcPro. I currently can't drag layers into  Geoprocessing boxes or rearrange my table of contents.
I find it unbelievable that no-one at ESRI experiences this.
Bud
Esri Case #03635777 - Dragging Catalog item to Contents pane doesn't always work
Case closed. Could not reproduce.
