ArcGIS Pro 3.1.1
Most of the time, dragging a Catalog item to the Contents pane works as expected. But sometimes when I attempt to drag an item, the Contents pane won't allow me to drop the item (the rectangle in the Contents pane that indicates an item can be dropped doesn't show up).
Video:
(The yellow circle around the mouse pointer indicates that the mouse button has being clicked/is being dragged.)
Sometimes, the issue is that I've accidently single-clicked the item name and put it into rename-mode. Which seems to prevent dragging & dropping. I don't know if that's operator error or not.
But other times, the dragged item simply can't be dropped. Such as the first attempt in the video.
Has anyone else had that issue? Have you been able to narrow it down to a specific scenario/root cause?
Thanks.
Full video: Mobile GDB spatial database view — Can't open attribute table directly using 'Open Table' in Catalog. I tried reproducing the steps in that video but didn't see the drag-and-drop issue this time.
