Distance Calculation Python output Error
1018
12-09-2024 12:15 PM
ParyaZareie
Hello everyone,
Our team is currently working on a distance calculation project in ArcGIS Pro to evaluate driving times between patients and a facility, with a 10-minute cutoff. We are developing a Python script for this task using the built-in notebook in ArcGIS Pro.
The final step of our process involves converting the resulting .gdb or .lyrx file into a CSV for further analysis. While we have successfully saved the solved OD Cost Matrix layer as a layer file on disk, we’ve encountered challenges in converting these files into a CSV or Excel format.
When attempting to convert the file into a pandas DataFrame or CSV to make it readable by a database, we encounter the error:
Error 999999: Something unexpected caused the tool to fail.
Any assistance or guidance would be greatly appreciated!
Any help greatly appreciated.
Tags (1)
DanPatterson
MVP Esteemed Contributor
If it is the table you are trying to export, see
Export Table (Conversion)—ArcGIS Pro | Documentation
... sort of retired...
ParyaZareie
We don't have a table yet to export. The output that we saved on disk is the .gdb file. We need to convert it into either CSV or Panda dataframe.
DanPatterson
you can't convert a gdb
you can convert a table in a gdb, once you have opened the table in Pro and tried the tool that is suggested
