Display values in legend when using Allow symbol property connections
953
03-10-2020 11:45 AM
RobertBorchert
Honored Contributor
I am using symbol property connections.  I place specific Hex code values in a text field for each feature.
I go through the procedure to use those hex values.
It works great.  Each polygon is the desired color.
However, the legend only shows the base color that was the original color.
I tried adding all values. Then I selected one and changed it to the Attribute Mapping field and it changed the color, but not in the symbol color list.
How can I display the colors in the legend?
Tags (1)
RobertBorchert
Honored Contributor
And I should add I am trying to avoid setting all 253 features one at a time.
