Display multiple symbols side by side for a single point
2808
07-08-2022 03:45 PM
GPear
I am trying to recreate a National Park Service map for an assignment, and am having trouble with point data I digitized. I want to show that a single point has both a campground and a picnic area, but it seems I can only show one symbol per point. The only solution I can think of is to create three layers and have the third layer, which would contain points that are both campgrounds and picnic areas, display only one, offset symbol. Is there a better way to do this? I'm using ArcGIS Pro 2.9.3.
RPGIS
by MVP Regular Contributor
You can symbolize points based on multiple attributes by selecting unique values, depending on what they are, and modify the point symbology to have different symbols based on the values.
You can then modify the symbology settings (far right tab in the symbology tab) where you can basically add various layers to the symbol and modify each layer based on what you want to symbolize for each attribute.
