Dimension Feature Class in Planar Mode Want to Change to Geodesic Mode
1278
11-08-2021 02:27 PM
AmandaPesel
I am dimensioning in ArcGIS Pro 2.8 in feet in planar mode, but I want to show the dimension the value in geodesic mode. I have tried changing the number the attribute table by changing USE CUSTOM LENGTH field to 1 and changing the value of the dimension in CUSTOM LENGTH field. In the screenshot below, the dimension is 36 feet measured in the planar mode, but I want the dimension to say 26 feet in the geodesic mode. When I changed it in the CUSTOM LENGTH field, the dimension shows it is 85 feet. Do you know what is going on here?
DanPatterson
MVP Esteemed Contributor
Web Mercator coordinate system?
... sort of retired...
AmandaPesel
The Web Mercator Coordinate system is WGS 1984 Web Mercator (auxiliary sphere).
DanPatterson
totally not the projection to use for anything entailing measurements (Google it or look on the forum)
I don't think arc* anything corrects for measurements on this projection
Measuring distances and areas when your map uses the Mercator projection (esri.com)
