Deleting 'utility network' crashes ArcGIS Pro
1829
06-11-2018 04:44 AM
AbhijeetKulkarni
hi all,
If I have utility network created either by 'create utility network' or by 'stage utility network' and if  want to  delete it by 'right click> Delete', it crashes ArcGIS Pro. Is there other way to delete 'utility network'?
ArcGIS PRO version: 2.1.2
Database:Oracle 12c
Thanks.
DanPatterson_Retired
there are a load of deletes associated with the utility network
Delete Network Category—Utility Network Toolbox | ArcGIS Desktop
Delete Rule—Utility Network Toolbox | ArcGIS Desktop
Delete Terminal Configuration—Utility Network Toolbox | ArcGIS Desktop
plus others.
I suspect that deleting things which are interconnected might lead to a crash
AbhijeetKulkarni
Hi Dan,
I get your point. If I have created and assigned network categories, rules , terminal configurations etc then I should be deleting those first. Thing is, ArcGIS Pro crashes even when I try to delete UN which have just created and none of rest configs created.
Thanks.
Did you remove it from the project first? assuming some remnants are present in pro
