Dates not showing in ArcGIS Pro Catalog
2573
10-04-2019 06:48 AM
SusanZwillinger
I've seen screen captures of other users showing dates for feature classes showing in the Catalog View for ArcGIS Pro.  I don't see any dates in my Catalog View.  I am using ArcGIS Pro 2.4.2.  How do I get the dates to show up?  It would also be nice to be able to search a folder and find all feature classes that had been modified on a specific date or date range.
Susan
ThomasColson
You'll have to be more specific about what the screen shots are showing (exactly what type of data? ) Not showing SDE and FGDB feature class dates in Cat View is a known issue. Shapefile dates do display.
SusanZwillinger
This is a simple file geodatabase.  You can see from the screen capture below that the dates for the feature classes are not visible even though there is a "Date" column:
George_Thompson
Esri Notable Contributor
I saw the same behavior. Now in ArcCatalog, I saw that the dates would show (if added). I do not see a way in ArcGIS Pro.
Update: https://community.esri.com/message/858662-date-modified-catalog-view-in-pro   see this post
--- George T.
