Databricks ODBC connection from ArcGIS Pro
420
04-17-2026 07:36 AM
SanchezNuñez
Good morning,
I am able to create and test successfully a connection from ArcGIS Pro to Databricks via OBDC. But when I click in the connection to open it and see its content it returns an "Unspecified error"
Robert_LeClair
Esri Esteemed Contributor
From a Support Services case - "Databricks is not officially supported by Esri, so the interaction between the Databricks platform and ArcGIS applications may be uncertain."
And there is an enhancement request July 2025:  ENH-000170840 : Add Databricks as a supported cloud data warehouse connection for ArcGIS Pro.
CWgis
Hi
Did you have any luck in fixing it?
I try this Connect to Databricks Using an OLE DB Connection from ArcGIS Pro
and got the ODBC connection using OAuth2.0 auth.
But when I login to Arcgis pro and setup my OBDC connection in Catalog I don't see any of the database files.
Any tips?
