Database connection error
5392
01-29-2015 06:12 AM
TimWitt2
Good morning,
I was trying to setup my database connection but I run into the following error.
I am using the same credentials and Instance that I use for ArcGIS Desktop. Any idea what could be the issue?
Tim
George_Thompson
Esri Notable Contributor
Hi Tim,
It looks like you may need to install the 64-bit Oracle client, as ArcGIS Pro is a 64-bit application. You can download the appropriate client form the Oracle website.
Here is a link to Oracles Instant Clients
Here is some more information related to setting up a database connection in Pro:
Look at the section on "Setting up a connection to Oracle"
Please post the results after installing/configuring the 64-bit client.
-George
GeodatabaseManaging DataEsri Technical Support
--- George T.
TimWitt2
I have figured it out, I need to install the 64bit client.
George_Thompson
Hi Tim,
-George
--- George T.
TimWitt2
Thanks George,
this is a better answer
Tim
