Data Clock date parameters
1562
10-22-2018 10:52 AM
AndrewHargreaves2
According to the Data Clock help documentation:
Data clocks split a Date field into Rings and Wedges.
So how do I get my Ring to show hours, instead of weeks or years, which are the only options? My DATETIME_OPERATED is a full on Date and Time record and I'd like to leverage it as such.
DanPatterson_Retired
Sounds like a good candidate for ArcGIS Ideas
AndrewHargreaves2
Yep, here's the response from Esri Technical Support‌:
Unfortunately it looks like the Data Clock is not designed to chart by hour at this time. We can definitely put in an enhancement request for that functionality, as well as being able to manually change the intervals. Please let me know if you would like to proceed with the Enhancement.
So, how is this a clock!? If it can't get more fine grained then a day, it's a calendar!
