Custom Project Template options
2139
03-01-2022 03:29 PM
Labels (2)
AaronKoelker
When creating custom project templates in ArcGIS Pro, is it possible to have the template create a particular folder structure within its project folder? For example, if I wanted all my new projects to come with an empty Windows folder for Images, Exports, Data etc... in addition to the default file geodatabase and toolbox that it generates?
If so, how would one do this? I'm not seeing a lot of in-depth guidance on what can and can't be set with custom project templates in ArcGIS Pro.
-Aaron
ABishop
MVP Alum
Hello Aaron,
I found this ArcGIS Pro help tutorial online that walks you through creating a project template.  Hope this helps!  https://pro.arcgis.com/en/pro-app/2.8/help/projects/create-your-own-project-template.htm
Amanda Bishop, GISP
JonathanDewalt
Did you ever get an answer to this.  Working on the same issue.
TorbjørnDalløkken2
